Add fall-back to Multiple Response columns
There are plenty of JMP platforms which do not support Multiple response columns. Currently I'm dealing with these manually in some way (or another) before I can continue with my work.
Add "Fall Back" option to Multiple Response columns. This fallback should "turn" the column internally to non-multiple response column if that column property cannot be utilized. Some fall-back strategies could be: first value, last value, combine values and none (default).
Why is this idea important?
Makes it less of a hassle to utilize Multiple Response columns when user could just define how they should be handled on column level (I'm thinking about using Tag for this), instead of creating new columns or something similar.
3 Comments
hogi
Level XIII
Create a Transform Column?
Sarah-Sylvestre
Level V
Thank you for submitting this request!
jthi
@jules this is the wish list I did mention in Discovery Summit regarding Multiple Response column property.
