This would help for example when making numeric encoding for character values. Dense Rank (wikipedia) or calculating orders
For example scipy.stats.rankdata offers average, min, max, dense and ordinal
very low hanging fruit
some minutes of programming -> many happy users
@mia_stephens
Besides a setting for JSL, Dense ranking should also be added to new formula column.
To keep the menu slim:
the current status or a modifier key (CTRL or Shift) could be used to control dense ranking yes/no
Related wish
Col N Categories
I concur...
Just asked about how to implement this functionality here:https://community.jmp.com/t5/Discussions/How-to-tweak-Col-Rank-to-give-consecutive-numbers-when-usin...
This is something that I encounter quite often and each time I have to write a small script\big formula for that.
many thanks
@Sarah-Sylvestre , maybe add a reverse version as well [via the right click new formula column menu] ?How to filter to show last n items/values?
For standard Rank, there is such an option:
Similar benefit for Dense Ranking [= Col Score()].
