Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
It'd be great if you didn't have to go back (from say Graph Builder) to the data table to find and change the Value Ordering properties, by instead simply double clicking on the X-Axis settings and editing the Vlaue Ordering from there..
In JMP 16, when a categorical axis has a non-default order, (e.g., you've chosen another column to order the axis by), you'll have an option to save the order as a Value Order property.
