Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
It'd be great if you didn't have to go back (from say Graph Builder) to the data table to find and change the Value Ordering properties, by instead simply double clicking on the X-Axis settings and editing the Vlaue Ordering from there..
In JMP 16, when a categorical axis has a non-default order, (e.g., you've chosen another column to order the axis by), you'll have an option to save the order as a Value Order property.
