%3CLINGO-SUB%20id%3D%22lingo-sub-384420%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EAggiungere%20VIF%20alla%20diagnostica%20DOE%3C%2FLINGO-SUB%3E%0A%20%20%3CLINGO-BODY%20id%3D%22lingo-body-384420%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%20%20%20%3CP%3EAttualmente%2C%20vediamo%20le%20VIF%20solo%20dopo%20aver%20utilizzato%20il%20pulsante%20Crea%20tabella%20e%20simulato%20una%20risposta%2C%20per%20poi%20esaminare%20l'output%20di%20Adatta%20modello%2C%20presupponendo%20che%20gli%20utenti%20abbiano%20aggiunto%20l'opzione%20VIF%20alle%20Preferenze%20o%20altri%20metodi%20per%20visualizzarle.%20Tuttavia%2C%20le%20VIF%20sono%20strumenti%20diagnostici%20di%20progettazione%20e%2C%20come%20tali%2C%20dovrebbero%20apparire%20nella%20sezione%20Diagnostica%20di%20progettazione.%20Apportare%20questa%20modifica%20o%20aggiunta%20velocizzer%C3%A0%20la%20generazione%20del%20progetto%20da%20parte%20dell'utente%2C%20soprattutto%20per%20i%20modelli%20di%20secondo%20e%20di%20ordine%20superiore.%3C%2FP%3E%0A%20%20%3C%2FLINGO-BODY%3E%0A%20%20%3CLINGO-LABS%20id%3D%22lingo-labs-384420%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%20%20%20%3CLINGO-LABEL%3EPersonalizzazione%20di%20massa%3C%2FLINGO-LABEL%3E%0A%20%20%3C%2FLINGO-LABS%3E%0A%20%0A%3CLINGO-SUB%20id%3D%22lingo-sub-843966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Aggiungere%20VIF%20alla%20diagnostica%20DOE%20-%20Stato%20modificato%20in%3A%20S%C3%AC%2C%20rimanete%20sintonizzati!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-843966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-848298%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Aggiungere%20VIF%20alla%20diagnostica%20DOE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-848298%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EVedo%20che%20%C3%A8%20in%20fase%20di%20sperimentazione%20in%20JMP%2019%20EA.%20Ho%20inviato%20un%20ticket%20(caso%2000174254)%3A%20non%20%C3%A8%20lo%20stesso%20VIF%20che%20vedrai%20nell'output%20di%20Fit%20Model.%20Sembra%20strettamente%20correlato%20ai%20valori%20nella%20scheda%20Estimation%20Efficiency%20nell'output%20di%20Evaluate%20Design.%20Ho%20generato%20Central%20Composite%20Design%20ortogonali%20in%20cui%20tutti%20i%20VIF%20sono%20uguali%20a%201%2C%20ma%20i%20VIF%20di%20Evaluate%20Design%20indicano%20la%20maggior%20parte%20dei%20termini%20con%20VIF%20%26gt%3B%202.%20Anche%20VIF%20%C3%A8%20nascosto%20per%20impostazione%20predefinita%3A%20devi%20sapere%20come%20fare%20clic%20con%20il%20pulsante%20destro%20del%20mouse%20sulla%20tabella%20per%20scoprirlo.%20Consiglierei%20anche%20di%20mostrarlo%20per%20impostazione%20predefinita.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ESperiamo%20che%20questo%20problema%20venga%20risolto%20con%20l'uscita%20del%20prodotto%20in%20produzione.%3C%2FP%3E%3C%2FLINGO-BODY%3E%0A%20%0A%20%0A%20%20%3CLINGO-SUB%20id%3D%22lingo-sub-902662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Aggiungi%20VIF%20alla%20diagnostica%20DOE%20-%20Stato%20modificato%20in%3A%20Consegnato%3C%2FLINGO-SUB%3E%0A%20%20%3CLINGO-BODY%20id%3D%22lingo-body-902662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3C%2FLINGO-BODY%3E%0A%20%0A%20%0A%20%20%3CLINGO-SUB%20id%3D%22lingo-sub-906281%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Aggiungere%20VIF%20alla%20diagnostica%20DOE%3C%2FLINGO-SUB%3E%0A%20%20%3CLINGO-BODY%20id%3D%22lingo-body-906281%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%20%20%20%3CP%3EGrazie%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F4320%22%20target%3D%22_blank%22%3E%40jszarka%3C%2FA%3E%20%2C%20abbiamo%20segnalato%20il%20problema.%20Lo%20riportiamo%20nella%20sezione%20%22Riconosciuto%22.%3C%2FP%3E%0A%20%20%3C%2FLINGO-BODY%3E%0A%20%0A%20%0A%20%20%3CLINGO-SUB%20id%3D%22lingo-sub-906282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Aggiungi%20VIF%20alla%20diagnostica%20DOE%20-%20Stato%20modificato%20in%3A%20Riconosciuto%3C%2FLINGO-SUB%3E%0A%20%20%3CLINGO-BODY%20id%3D%22lingo-body-906282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3C%2FLINGO-BODY%3E%0A%20%0A%20%0A%20%20%3CLINGO-SUB%20id%3D%22lingo-sub-906284%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Aggiungere%20VIF%20alla%20diagnostica%20DOE%3C%2FLINGO-SUB%3E%0A%20%20%3CLINGO-BODY%20id%3D%22lingo-body-906284%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%20%20%20%3CP%3ELa%20mia%20speranza%20%C3%A8%20che%20i%20VIF%20corrispondano.%20Una%20volta%20implementato%2C%20suggerirei%20anche%20di%20visualizzarlo%20di%20default%20nella%20scheda%20%22Efficienza%20di%20stima%22%2C%20poich%C3%A9%20sarebbe%20improbabile%20che%20la%20maggior%20parte%20degli%20utenti%20si%20accorgesse%20che%20%C3%A8%20nascosto%20l%C3%AC.%3C%2FP%3E%0A%20%20%3C%2FLINGO-BODY%3E
Add VIFs to DOE diagnostics
Currently, we see VIFs only after using the Make Table button and simulating a response, then examining Fit Model output, assuming users have added the VIF option to Preferences or other means of revealing them.  But VIFs are design diagnostics, and as such should appear in the design diagnostics section.  Making this change or addition will speed user design generation especially for second and higher order models.
8 Comments
jszarka
Level V
This is what I saw as JMP's take on this in the past -- Include VIF in Evaluate Design
Audrey_Shull
jszarka
Level V
I see this is being piloted in JMP 19 EA. I have submitted a ticket (Case 00174254) - it is not the same VIF you will see in the Fit Model output. It seems closely related to the values in the Estimation Efficiency tab in the Evaluate Design output. I've generated orthogonal Central Composite Designs where the VIFs all equal 1, but the Evaluate Design VIFs indicate most terms with VIF > 2. VIF is also hidden by default - you have to know to right-click on the table to uncover it. I'd also recommend showing it by default.
Hopefully this will be remedied by the production release.
Status changed to: Delivered
jszarka
Level V
I see the results delivered, but it isn't great per Case 00174254. Below is a 3-factor CCD with n=20 and the CCD-Uniform Precision design type chosen. With simulated data the VIFs are all close to 1, but the Evaluate Design platform looks a bit worse, with no results equal to 1.
mia_stephens
Thank you @jszarka , we have captured this issue. Moving this back to acknowledged.
mia_stephens
jszarka
Level V
My hope would be that the VIFs would end up matching. After that is implemented, I would also suggest this show up by default in the Estimation Efficiency tab as it would be unlikely that most users would know that it is hidden there.
