キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
言語を選択 翻訳バーを非表示
Add JMP Version and product to icon options
I have to have multiple JMP versions installed at the same time, and from time to time I get confused which version I'm currently running. I can always check it from About menu or create an addin which will tell me the version + product, but I would rather use icons for that.
Currently I have three different JMP versions in "active" use (even more versions installed...). I have pinned them to taskbar and changed the icons but
with the current icon selection I cannot choose to show the current version, differentiate between pro/non-pro or if the JMP is EA product.
Current icon selection JMP16 Pro:
My current selections to help me make a difference between different versions:
  1. JMP15
  2. JMP16 Pro
  3. JMP17 EA
6件のコメント
jpol
Level IV
Great idea.
I too need to run several versions of JMP simultaneously. This would help prevent using the wrong version for some applications.
ih
Super User (Alumni)
Super User (Alumni)
I agree with making this a built-in option, but FYI my current solution is to make a custom icon file (save a 32x32 pixel .png file and change extension to .ico) and then reference that file in the dialog box you showed.
変更されたステータス: Acknowledged
Hi @jthi, thank you for your suggestion! We have captured your request and will take it under consideration.
変更されたステータス: Not Planned For Now
We appreciate you submitting this idea, but we do not plan to pursue this at this time. I'm changing the status to Not Planned for Now, although I will update this wish if we revisit this request in a future release.
hogi
Level XIII
I just found this wish list entry
which is very close to my recent question to JMP beta: 00152162
Another issue: also inside a JMP window it's quite difficult to find out, which window is JMP16, 17, 18, 19 ...
The solution: small markers added to the menu : )
@Jeff_Perkinson
@tonya_mauldin
@PatrickGiuliano
I generated a set of AddIns and submitted it via community
- once it passes the "referee" process, I will post an update ...
... can't live without anymore : )
hogi
Level XIII
@MShroff @FN @Metin_Tueluemen @Alainmd02 @pauldeen @AW @klbstats @JohnDMoore1 @ih @nao @Sburel @jpol @The_Annie @andersonmj2 @mes
review process is completed : )
the AddIns are now available for download:
Identify different JMP versions
