JMP Tips
Search Preferences (Windows)
Can't find a setting in Preferences? Do a search.
  1. Select File > Preferences.
  2. In the Filter box at top, enter your text.
  3. To filter by JMP version, click Version and choose a range to search within.
  4. At left, click a category to see its results.
Preferences that match your search term are highlighted. If you filter by different versions, the version when the preference was added appears next to the highlighted preference.
Search Results for PreferencesSearch Results for Preferences
