JMP Tips
Restore Default Axis Settings (Windows)
Change the scale of a plot by clicking in the frame with the Magnifier tool Magnifier ToolMagnifier Tool or by rescaling the axes. Restore the original scaling using any of the following actions:
  • Hold the Alt key and click in the frame with the Magnifier tool
  • Double-click in the frame with the Magnifier tool
  • Right-click the axes and select the Revert Axis command
Revert Axis
