JMP Tips
Reorder Histograms
In the Distribution platform, you can change the order of a histogram for a categorical variable.
  1. From the red triangle menu for the categorical variable, select Order By and choose Count Descending or Count Ascending.
  2. (Optional) To save the new order to the data table (as a value ordering property), select Save > Value Ordering.
Reordering a HistogramReordering a Histogram
