JMP Tips
Preview the Distribution Behind an Aggregation in Hover Label Graphs
Do you want to see and compare the distribution of the data behind aggregated visual elements, like slices in a pie chart, tiles in a treemap, or bars in a bar chart? Add a histogram, heatmap, or box plot to a hover label.
  1. In a JMP graph, right-click and select Hover Label.
  2. Select the type of graph you want to add.
  3. Select a Hover Label TypeSelect a Hover Label Type
  4. Hover over an element in the graph.
  5. Show a Hover LabelShow a Hover Label
  6. (Optional) To pin a hover label to a graph, hover over the label and at the top right, click the Pin icon.
  7. (Optional) To move the hovel label on a graph, drag it to a new position. A tag line appears to show which bar the label is associated with.
For more information, see the hover labels section in the JMP Online Help.
