JMP Tips
Order Values in Reports
By default, JMP always presents a variable's levels in alphabetical order. This is not always desirable. For example, you usually prefer to see seasons in chronological order, not alphabetical order.
  1. Right-click on the column name and select Column Info.
  2. Select Column Properties > Value Order.
  3. Use the Move Up and Move Down buttons to specify the correct ordering.
Value OrderingValue Ordering
