JMP Tips
Group Columns
When you have a large number of columns, organize them by grouping. When you launch a platform, you can add the group instead of adding each column individually.
To group columns:
  1. Open a data table.
  2. In the Columns panel, highlight the columns that you want to group.
  3. Right-click on the highlighted columns in the Columns panel and select Group Columns.
Grouping ColumnsGrouping Columns
