JMP Tips
Expand and Collapse Blocks of JSL Code (Windows)
Code folding markers show the beginning and the end of the code block, so you can collapse and expand code.
To turn on code folding:
  1. Select File > Preferences > Script Editor.
  2. Select Code folding.
  3. Click OK.
Note: By default, code does not remain collapsed after you save the script and restart JMP. To save the state of the folded code, select Save and restore document state information in the Script Editor preferences.
JSL Code FoldingJSL Code Folding
