JMP Tips
Exclude Points
If you suspect that a point is exerting undue influence on your fit, you can exclude it.
  1. Right-click the point.
  2. Select Row Exclude.
When you add a new fit, it does not include the excluded point.
Row Exclude OptionRow Exclude Option
Excluding a Point
