Learning Library
Change Treemap Layout for Easier Comparison
For ease of comprehension, use Squarify to arrange the rectangles in order of size in your treemap. The largest rectangle appears in the top left corner and the smallest rectangle appears in the lower right corner.
Turn on Squarify:
  • From Graph Builder: In the Treemap properties panel, change the Layout to Squarify.
  • From Treemap: In the launch window, select Squarify from the Layout list.
Example of SquarifyExample of Squarify
