Learning Library
Capture a JMP Workflow
If you find yourself doing the same steps over and over in JMP, capture your steps with Workflow Builder. It is like an advanced macro that records your actions in JMP so that you can replay them or share them with others.
  1. Select File > New > Workflow.
  2. Click Record to start recording.
  3. Perform your steps in JMP, like opening a data table and performing analyses. As you complete an analysis, close the window to record it.
  4. Click Record again to stop recording.
  5. To test and confirm the workflow, click Play.
  6. To save the workflow, click File > Save.
  7. To share the workflow, click the Workflow Builder red triangle and select Create Workflow Package. You can send the package to a JMP user and they can play the workflow.
Capture a JMP workflowCapture a JMP workflow
