Hi,
Sometimes I have to combine a lot of excel files. But "Import multiple files" menu would not work for excel files properly. So I wrote a JSL for it and I would like to share it here. It starts with select an excel file and open it using excel import wizard. Then the script gets import settings and files list in the directory. Finally, open all excel files (.xls, xlsx, xlsm) in the directory and combine them. Final dataset contains source files column at the right end of the table.
I hope that this script will help your work. Any feedback would be really appreciated!
