// This Simple script illustrate a method to allow the axis settings from
// one platform, to replicate the same settings in a different platform's
// graph.
// This example places both platform's utput in the same window, but
// they could reside in separate window is that is what is desired
Names Default To Here( 1 );
// Initialize Flagging Variables
// These variables will hold the last ettings for the
// Y Origin and Y Range for each graph. When one of the
// Y axes is changed, it will be detected by comparing it with
// the last value that is being held in these columns
BivYOrigin = 0;
BivYRange = 0;
OWYOrigin = 0;
OWYRange = 0;
// Create a simple display output
New Window( "One Axis Setting Changes Both Graphs",
H List Box(
OW= dt << Oneway(
Y(:height ),
X(:sex ),
Means(1 ),
Box Plots( 1 ),
Mean Diamonds( 1 ),
SendToReport(
Dispatch(
"Oneway Plot",
FrameBox,
{DispatchSeg(Box Plot Seg( 1 ), {Box Type( "Outlier" ), Line Color( "Red" )} ),
DispatchSeg(Box Plot Seg( 2 ), {Box Type( "Outlier" ), Line Color( "Red" )} ),
Row Legend(
sex,
Color(1 ),
Color Theme( "JMP Default" ),
Marker( 0 ),
Marker Theme( "" ),
Continuous Scale( 0 ),
Reverse Scale( 0 ),
Excluded Rows( 0 )
Biv= dt << Bivariate(
Y(:height ),
X(:weight ),
Fit Where( :sex == "F", Fit Line( {Line Color( {213, 72, 87} )} ) ),
Fit Where( :sex == "M", Fit Line( {Line Color( {64, 111, 223} )} ) )
// Add a graphic script to the OneWay graph, that detects the
// changes to it's Y Axis, and copies the new settings to
// the Y Axis of the Bivariate Plot
Report( OW )[Frame Box( 1 )] << add graphics script(
// Check for a change
If( OWYOrigin != Y Origin() | OWYRange != Y Range(),
// If a change is found, copy the new Y Origin and Y Range
// to the Flagging(Holding) variables
OWYOrigin= Y Origin();
OWYRange= Y Range();
// Copy the new axis settings from the OneWay display
// to the Bivariate Y Axis
Report( OW )[Axis Box(1 )] << Copy Axis Settings;
Report( Biv )[Axis Box( 1 )] << Paste Axis Settings;
// Add the graphic script to the Bivariate plot to perform the
// same actions, but from the Bivariate plot's point of view.
Report( Biv )[Frame
If( BivYOrigin != Y Origin() | BivYRange != Y Range(),
BivYOrigin= Y Origin();
BivYRange= Y Range();
Report( Biv )[Axis Box( 1 )] << Copy Axis Settings;
Report( OW )[Axis Box(1 )] << Paste Axis Settings;
