    Regular business hours will resume at 9:00 a.m. ET on Friday, Jan. 2, 2026.
A Simple Script to Illustrate Axis Changes in One Chart Controling the Axis in a Different Chart
txnelson
// This Simple script illustrate a method to allow the axis settings from
// one platform, to replicate the same settings in a different platform's
// graph.
// This example places both platform's utput in the same window, but
// they could reside in separate window is that is what is desired
Names Default To Here( 1 );
// Initialize Flagging Variables
// These variables will hold the last ettings for the
// Y Origin and Y Range for each graph.  When one of the
// Y axes is changed, it will be detected by comparing it with
// the last value that is being held in these columns
BivYOrigin = 0;
BivYRange = 0;
OWYOrigin = 0;
OWYRange = 0;
// Create a simple display output
New Window( "One Axis Setting Changes Both Graphs",
       H List Box(
              OW= dt << Oneway(
                     Y(:height ),
                     X(:sex ),
                     Means(1 ),
                     Box Plots( 1 ),
                     Mean Diamonds( 1 ),
                     SendToReport(
                           Dispatch(
                                  "Oneway Plot",
                                  FrameBox,
                                  {DispatchSeg(Box Plot Seg( 1 ), {Box Type( "Outlier" ), Line Color( "Red" )} ),
                                  DispatchSeg(Box Plot Seg( 2 ), {Box Type( "Outlier" ), Line Color( "Red" )} ),
                                  Row Legend(
                                         sex,
                                         Color(1 ),
                                         Color Theme( "JMP Default" ),
                                         Marker( 0 ),
                                         Marker Theme( "" ),
                                         Continuous Scale( 0 ),
                                         Reverse Scale( 0 ),
                                         Excluded Rows( 0 )
              Biv= dt << Bivariate(
                     Y(:height ),
                     X(:weight ),
                     Fit Where( :sex == "F", Fit Line( {Line Color( {213, 72, 87} )} ) ),
                     Fit Where( :sex == "M", Fit Line( {Line Color( {64, 111, 223} )} ) )
// Add a graphic script to the OneWay graph, that detects the
// changes to it's Y Axis, and copies the new settings to
// the Y Axis of the Bivariate Plot
Report( OW )[Frame Box( 1 )] << add graphics script(
       // Check for a change
       If( OWYOrigin != Y Origin() | OWYRange != Y Range(),
              // If a change is found, copy the new Y Origin and Y Range
              // to the Flagging(Holding) variables
              OWYOrigin= Y Origin();
              OWYRange= Y Range();
              // Copy the new axis settings from the OneWay display
              // to the Bivariate Y Axis
              Report( OW )[Axis Box(1 )] << Copy Axis Settings;
              Report( Biv )[Axis Box( 1 )] << Paste Axis Settings;
// Add the graphic script to the Bivariate plot to perform the
// same actions, but from the Bivariate plot's point of view.
Report( Biv )[Frame
Box(
       If( BivYOrigin != Y Origin() | BivYRange != Y Range(),
              BivYOrigin= Y Origin();
              BivYRange= Y Range();
              Report( Biv )[Axis Box( 1 )] << Copy Axis Settings;
              Report( OW )[Axis Box(1 )] << Paste Axis Settings;
Comments
Very impressive, Jim. Worked great for synchronizing changes to the left and right y-axes in Graph Builder. Thank you for posting!
