This website uses Cookies. Click Accept to agree to our website's cookie use as described in our Privacy Policy. Click Preferences to customize your cookie settings.
Submit your abstract to the call for content for Discovery Summit Americas by April 23. Selected abstracts will be presented at Discovery Summit, Oct. 21- 24.
Discovery is online this week, April 16 and 18. Join us for these exciting interactive sessions.
This is just what I have been attempting to do but I have been unable to plot this as a map of the UK in Graph Builder without breaking the data into county levels.
Does anyone have any idea how I can plot this data into a map of the UK but using the Area column?
Thanks for trying out the JMP mapping with the Brexit Results data!
As you have seen JMP includes some maps with the package, but only down to the county level for the UK.
To get down to a lower level (in this case the Area (city/town) level that is in the Brexit Results, you would need to bring in a custom shape map that contains the info to draw each of these Areas. Once you see the underlying tables needed (naming and shape files) you can create your own (a little time consuming) or import in and adapt an already created shape file (probably the best option here). Then put these into the folder your are mapping from in JMP and you should be ready to go. Here is a link to learn a little more: http://www.jmp.com/support/help/Examples_of_Creating_Maps.shtml
There is another way to view the data that might be helpful as well. If you add both a representative latitude and longitude columns to the datatable for each of the Areas, you can then plot these on a Graph Builder of Bubble Plot over the underlying built-in UK county shapes or any other geographic map. Not the same as having a break out map shape for each Area as you would with a custom mapping view, but might still give you the visual you want.
Shown above is a quick example on just a few rows of the Brexit Results data.
Hope this helps!
var data = div.getElementsByClassName("video-js");
var script = document.createElement('script');
script.src = "https://players.brightcove.net/" + data_account + "/" + data_palyer + "_default/index.min.js";
for(var i=0;i< data.length;i++){
videodata.push(data[i]);
for(var i=0;i< videodata.length;i++){
document.getElementsByClassName('lia-vid-container')[i].innerHTML = videodata[i].outerHTML;
document.body.appendChild(script);
catch(e){
/* Re compile html */
$compile(rootElement.querySelectorAll('div.lia-message-body-content')[0])($scope);
if (code_l.toLowerCase() != newBody.getAttribute("slang").toLowerCase()) {
/* Adding Translation flag */
var tr_obj = $filter('filter')($scope.sourceLangList, function (obj_l) {
return obj_l.code.toLowerCase() === newBody.getAttribute("slang").toLowerCase()
if (tr_obj.length > 0) {
tr_text = "This post originally written in lilicon-trans-text has been computer translated for you. When you reply, it will also be translated back to lilicon-trans-text.".replace(/lilicon-trans-text/g, tr_obj[0].title);
try {
if ($scope.wootMessages[$rootScope.profLang] != undefined) {
tr_text = $scope.wootMessages[$rootScope.profLang].replace(/lilicon-trans-text/g, tr_obj[0].title);
} catch (e) {
} else {
//tr_text = "This message was translated for your convenience!";
try {
if (!document.getElementById("tr-msz-" + value)) {
var tr_para = document.createElement("P");
tr_para.setAttribute("id", "tr-msz-" + value);
tr_para.setAttribute("class", "tr-msz");
tr_para.style.textAlign = 'justify';
var tr_fTag = document.createElement("IMG");
tr_fTag.setAttribute("class", "tFlag");
tr_fTag.setAttribute("src", "/html/assets/lingoTrFlag.PNG");
tr_fTag.style.marginRight = "5px";
tr_fTag.style.height = "14px";
tr_para.appendChild(tr_fTag);
var tr_textNode = document.createTextNode(tr_text);
tr_para.appendChild(tr_textNode);
/* Woot message only for multi source */
if(rootElement.querySelector(".lia-quilt-forum-message")){
rootElement.querySelector(".lia-quilt-forum-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-message-view-blog-topic-message")) {
rootElement.querySelector(".lia-message-view-blog-topic-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-blog-reply-message")){
rootElement.querySelector(".lia-quilt-blog-reply-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-tkb-message")){
rootElement.querySelector(".lia-quilt-tkb-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-tkb-reply-message")){
rootElement.querySelector(".lia-quilt-tkb-reply-message").insertBefore(tr_para,rootElement.querySelector(".lia-quilt-row.lia-quilt-row-footer"));
} else if(rootElement.querySelector(".lia-quilt-idea-message")){
rootElement.querySelector(".lia-quilt-idea-message").appendChild(tr_para);
}else if(rootElement.querySelector(".lia-quilt-column-alley-left")){
rootElement.querySelector(".lia-quilt-column-alley-left").appendChild(tr_para);
else {
if (rootElement.querySelectorAll('div.lia-quilt-row-footer').length > 0) {
rootElement.querySelectorAll('div.lia-quilt-row-footer')[0].appendChild(tr_para);
} else {
rootElement.querySelectorAll('div.lia-quilt-column-message-footer')[0].appendChild(tr_para);
} catch (e) {
} else {
/* Do not display button for same language */
// syncList.remove(value);
var index = $scope.syncList.indexOf(value);
if (index > -1) {
$scope.syncList.splice(index, 1);
angular.forEach(mszList_l, function (value) {
if (document.querySelectorAll('div.lia-js-data-messageUid-' + value).length > 0) {
var rootElements = document.querySelectorAll('div.lia-js-data-messageUid-' + value);
}else if(document.querySelectorAll('.lia-occasion-message-view .lia-component-occasion-message-view').length >0){
var rootElements = document.querySelectorAll('.lia-occasion-message-view .lia-component-occasion-message-view')[0].querySelectorAll('.lia-occasion-description')[0];
}else {
var rootElements = document.querySelectorAll('div.message-uid-' + value);
angular.forEach(rootElements, function (rootElement) {
if (value == '23856' && "TkbArticlePage" == "TkbArticlePage") {
rootElement = document.querySelector('.lia-thread-topic');
/* V1.1 Remove from UI */
if (document.getElementById("tr-msz-" + value)) {
document.getElementById("tr-msz-" + value).remove();
if (document.getElementById("tr-sync-" + value)) {
document.getElementById("tr-sync-" + value).remove();
/* XPath expression for subject and Body */
var lingoRBExp = "//lingo-body[@id = " + "'lingo-body-" + value + "'" + "]";
lingoRSExp = "//lingo-sub[@id = " + "'lingo-sub-" + value + "'" + "]";
/* Get translated subject of the message */
lingoRSXML = doc.evaluate(lingoRSExp, doc, null, XPathResult.UNORDERED_NODE_SNAPSHOT_TYPE, null);
for (var i = 0; i < lingoRSXML.snapshotLength; i++) {
/* Replace Reply/Comment subject with transalted subject */
var newSub = lingoRSXML.snapshotItem(i);
/*** START : extracting subject from source if selected language and source language is same **/
var sub_L = "";
if (newSub.getAttribute("slang").toLowerCase() == code_l.toLowerCase()) {
if (value == '23856') {
sub_L = decodeURIComponent($scope.sourceContent[value].subject);
else{
} else {
sub_L = newSub.innerHTML;
/*** End : extracting subject from source if selected language and source language is same **/
/* This code is placed to remove the extra meta tag adding in the UI*/
try{
sub_L = sub_L.replace('<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />','');
catch(e){
// if($scope.viewTrContentOnly || (newSub.getAttribute("slang").toLowerCase() != code_l.toLowerCase())) {
if ($scope.viewTrContentOnly) {
if ("TkbArticlePage" == "IdeaPage") {
if( (sub_L != "") && (sub_L != undefined) && (sub_L != "undefined") ){
document.querySelector('.MessageSubject .lia-message-subject').innerHTML = sub_L;
if ("TkbArticlePage" == "TkbArticlePage") {
var subTkbElement = document.querySelector('.lia-thread-subject');
if(subTkbElement){
document.querySelector('.lia-thread-subject').innerHTML = sub_L;
else if ("TkbArticlePage" == "BlogArticlePage") {
try {
if((sub_L != "") && (sub_L!= undefined) && (sub_L != "undefined")){
var subElement = rootElement.querySelector('.lia-blog-article-page-article-subject');
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
/* var subElement = rootElement.querySelectorAll('.lia-blog-article-page-article-subject');
for (var subI = 0; subI < subElement.length; subI++) {
subElement[subI].innerHTML = sub_L;
else {
try {
// rootElement.querySelectorAll('.lia-blog-article-page-article-subject').innerHTML= sub_L;
/** var subElement = rootElement.querySelectorAll('.lia-blog-article-page-article-subject');
for (var j = 0; j < subElement.length; j++) {
subElement[j].innerHTML = sub_L;
} catch (e) {
else {
try{
/* Start: This code is written by iTalent as part of iTrack LILICON - 98 */
if(document.querySelectorAll('.lia-quilt-forum-topic-page').length > 0){
if(rootElement.querySelector('div.lia-message-subject').querySelector('h5')){
rootElement.querySelector('div.lia-message-subject').querySelector('h5').innerText = decodeURIComponent(sub_L);
} else {
rootElement.querySelector('.MessageSubject .lia-message-subject').innerText = sub_L;
} else {
/* End: This code is written by iTalent as part of iTrack LILICON - 98 */
catch(e){
console.log("subject not available for second time. error details: " + e);
} else {
try {
/* Start: This code is written by iTalent as part of LILICON - 98 reported by Ian */
document.querySelector('.lia-js-data-messageUid-'+ value).querySelector('.MessageSubject .lia-message-subject').innerText = sub_L;
else{
/* End: This code is written as part of LILICON - 98 reported by Ian */
} catch (e) {
console.log("Reply subject not available. error details: " + e);
// Label translation
var labelEle = document.querySelector("#labelsForMessage");
if (!labelEle) {
labelEle = document.querySelector(".LabelsList");
if (labelEle) {
var listContains = labelEle.querySelector('.label');
if (listContains) {
/* Commenting this code as bussiness want to point search with source language label */
// var tagHLink = labelEle.querySelectorAll(".label")[0].querySelector(".label-link").href.split("label-name")[0];
var lingoLabelExp = "//lingo-label/text()";
trLabels = [];
trLabelsHtml = "";
/* Get translated labels of the message */
lingoLXML = doc.evaluate(lingoLabelExp, doc, null, XPathResult.UNORDERED_NODE_SNAPSHOT_TYPE, null);
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
