JMP Pro Library
XB Boost Presentation - 10-4-2023
In today's meeting, I unfortunately forgot to hit the record button to capture Peter's presentation. However, Peter mentioned a previously recorded web-session by JMP's Russ Wolfinger that covered XB Boost.
You can view Russ' presentation on XB Boost using the following link: https://community.jmp.com/t5/JMP-in-the-Upstream/JMP-in-the-Upstream-8-Deploying-XGBoost-algorithms-...
