  • JMP multivariate capabilities let you understand relationships between multiple variables simultaneously. See how. Friday, Aug. 14, 2 pm US ET.
JMP On Air
Things I Wish I Knew When I Started Using JMP (Episode 1)
(view in My Videos)
NY-area System Engineer Mike Anderson kicks off a regular series for JMP On Air: Things I Wish I Knew When I Started Using JMP. After completing his PhD., Mike entered the workforce and almost immediately began using JMP. As a brand-new engineer, Mike spent a lot of his early time using JMP “learning” through trial and error. In this series, Mike shares with you the five critical things that will help make your early days using JMP go smoothly. In this session, Mike covers Thing #1: Turning tables into graphs. Mike argues that putting a data table in front of someone isn’t very stimulating, but presenting data with graphics makes the information you’re trying convey stand out. Follow along as Mike shows you how easy it is to turn your data into basic, but incredibly helpful, JMP visualizations.
Comments
NP
Hello,
I am unable to get the video for this. I am signed in but it still is not available.
thanks!
Nicole
Hello, did the points that you had for your plot come from the picture directly? Or did you have the data from another file? I would like to learn more about how to take the six pictures and create the data that then creates the 3D graph.
Thanks!
