The Question Mark Tool
JMP offers top-notch Help tools and documentation on its website. But suppose you don’t know what to search for, or maybe you’re working inside the software and are curious about what a particular command or feature in JMP actually does. The Question Mark Tool in JMP is a quick and easy way to get answers immediately… from inside JMP. In this episode of Help!, Ross Metusalem shows you how to use the Question Mark Took, your direct route from within JMP to the appropriate section in Help Documentation.
Comments
Vball247
Thanks for showing the "under the hood" on the Helpkeys in the tree structure, now understand what those mean.
