JMP On Air
Episode 4 (April 10, 2020)
(view in My Videos)
Segment Description Who's On Air
Welcome
The Monologue
@julian
Featured Program End-to-End Analytics
A case study in analyzing home power data.
@Daniel_Valente
Mindful Moment Bhramari pranayama
Find some calm with the yoga breathing technique known as Bhramari breathing (also called bee breathing).
@arati_mejdal
Ask the DOE Doctor Garbage in, Goodies out
Best practices on getting your data into shape AKA techniques for cleaning your data.
@brady_brady
Have You Tried
Virtual Joins
Virtually join a main table to one or more auxiliary tables using Link ID and Link Reference column properties.
 @ryandewitt
Featured Program
Which Model When?
You have a business or research question, you’ve collected or found appropriate data, and you are ready to analyze. But which analytical methods should you try? And how will you choose a final model?
@MaryLoveless
@ruthhummel
Stats Snack Linear Regression
What is Linear Regression and how do I use it?
 @alisa_h_lowery
JMP in Action Functional Design of Experiments
See how to design and analyze an experiment where the response variable is a function (e.g., size or temperature over time) instead of a single point measurement.
@Ross_Metusalem
Tip of the Day Standardizing Your Column Attributes
Clean-up multiple columns at once using the standardize attribute tool.
@Peter_Hersh
@MaryLoveless
Closing The Last 5 @jules
