Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
JMP has powerful, world-class design of experiments (DOE) capabilities. See how to use the DOE platforms to make the most of your experiments. This topic may cover Custom Design, Constraints, Screening Design, and Split Plot Designs.
I would say that for more than 2 factors it is going to be too complicated to try something like the Fit Y by X approach. I would use the candidate set approach instead.
My feeling is that you are unlikely to be able to imagine constraints involving more than 3 factors (it makes my head hurt to think about it). Even 3 factors is unlikely IMO.
