JMP Library
Automating Your Analysis Workflow
The JMP Scripting Language (JSL) will give you the tools you need to make using JMP even more productive. This topic may cover saving scripts to journals and data tables, combining scripts to automate repetitive actions, and creating repeatable and reproducible analyses using the Enhanced Log and Workflow Builder.
This is part of the Get Going with JMP series.
Resources:
