JMP Knowledge Base
You see a syntax error after you run an AE Narrative report in JMP® Clinical 7.1 on a Chinese operating system
Running an AE Narrative report in JMP® Clinical 7.1 on a Chinese operating system might produce the following error:
ERROR 22-322: Syntax error, expect one of the following: quoted string, numeric constant, date time constant, missing value,-. 76: Unable to determine LINE and COLUMN.
This issue is corrected in the JMP® Clinical 7.1.2 hot fix. Click the link below to access the hot fix.
[Previously JMP Note 65959]
Details
Operating System
Windows
Reported Version
7.1
Fixed Version
8.0
Products JMP Clinical
