JMP Knowledge Base
You save a review template with a subject filter and an error occurs in JMP® Clinical 8.0
In JMP Clinical 8.0, when you save a review template with a subject filter, the action results in an error that is similar to the following:
could not find column{1} in access or evaluation of 'Column' ,
Column/*###*/("USUBJID")
In addition, the template fails to save.
Click here to access the Hot Fix for this issue.
[Previously JMP Note 67928]
Details
Operating System
Windows
Reported Version
8.0
Fixed Version
8.1
Products JMP Clinical
