JMP Knowledge Base
You are unable to see table or label text in JMP® 15 on Mac OS when running Dark Mode or High Contrast Mode
In JMP® 15 on Mac OS, you might not be able to see table or label text when running Dark Mode or High Contrast Mode.
The current workaround is to disable Dark Mode or High Contrast Mode. Alternatively, reverting the Colors selections in Styles of the Preferences menu back to Original might resolve the issue as well.
If this solution does not resolve the issue, contact JMP Technical Support for additional assistance.
[Previously JMP Note 66812]
Details
Operating System
macOS
Reported Version
15.0
Products JMP JMP Pro
