JMP Knowledge Base
Why are the parameter estimates I see in JMP® different from the GLM procedure in SAS®?
Differences between SAS® and JMP® are due to different parameterizations and algorithms used to calculate the statistics. The JMP algorithm is computationally more efficient, but PROC GLM is more general. Both are correct, just different. To answer any comparison questions, refer to the Nominal Factors section in the JMP Fitting Linear Models documentation and help.
[Previously JMP Note 37920]
Details
Operating System
macOS Windows
Products JMP JMP Pro
