JMP Knowledge Base
Which JMP® platforms are multi-threaded?
Some JMP platforms are multi-threaded, meaning that a single task can make use of more than one processor when they are available. In JMP 16, the following platforms are multi-threaded:
  • Boosted Trees*
  • Bootstrap Forest*
  • Choice
  • Covering Arrays*
  • Capability Analysis in Distribution
  • Explore Outliers
  • Explore Patterns
  • Factor Analysis
  • Fit Life by X
  • Fit Model: Parametric Survival, Mixed Model*, Generalized Regression*, and Response Screening*
  • Functional Data Explorer
  • Gaussian (Fast GASP* and the use of Categorical variables are only in JMP® Pro.)
  • K Nearest Neighbors*
  • Latent Class Analysis
  • Life Distribution
  • Multivariate
  • Neural (Some features are only in JMP Pro*.)
  • Nominal Logistic
  • Nonlinear and Nonlinear Curve
  • Normal Mixtures in Cluster Analysis
  • Partial Least Squares (Some features are only in JMP Pro*.)
  • Partition
  • Predictor Screening
  • Principal Components
  • Process Screening
  • Profiler (Does not apply to Profilers launched from within other platforms.)
  • Reliability Forecast
  • Repairable Systems Simulation*
  • Response Screening
  • Sparse Principal Components*
  • Structural Equation Models*
  • Support Vector Machines*
  • SVD Imputation in the Missing Values Screening
  • Text Explorer (*SVD and Latent Class Analysis are only in JMP Pro.)
  • Time Series Forecast
  • Uplift*
  • Variable Clustering
* These platforms are available only in JMP Pro.
[Previously JMP Note 49280]
Details
Operating System
macOS Windows
Reported Version
14.0
Products JMP
