JMP Knowledge Base
What to do if you launch JMP Genomics® but the Genomics Starter does not appear
If you launch JMP Genomics® and see only the JMP Home Window but no Genomics Starter, you may need to re-enable the Genomics and Life Sciences Add-Ins. To do this, select View ► Add-Ins. Find Genomics and Life Sciences and check the "Enabled" box for each. This should restore the Genomics Starter and menu.
[Previously JMP Note 47964]
Details
Operating System
Windows
Products JMP Genomics
