JMP Knowledge Base
What to do if you launch JMP Clinical® but the JMP Clinical Main Window does not appear
If you launch JMP Clinical® and see only the JMP Home Window but not the JMP Clinical Main Window, you may need to re-enable the Clinical and Life Sciences Add-Ins. To do this, select View ► Add-Ins. Find Clinical and Life Sciences and check the "Enabled" box for each. This should restore the JMP Clinical Main Window.
[Previously JMP Note 59379]
Details
Operating System
Windows
Products JMP Genomics JMP Clinical
