JMP Knowledge Base
Translation files for "Overall Response" for oncology analysis
In Chinese, there are four meanings of "Overall Response," with different translations in Chinese. These terms, loosely translated into English, are "Assessment," "Efficacy," "Remission," and "Response." The files in this note enable the different translations in Chinese.
To update the files in JMP® Clinical, first close JMP Clinical completely. Then back up the existing files. Finally, replace the existing files with the files in this note, as described below:
  • Replace the existing ProgressionFreeSurvivalPlots.sas file found in C:\Program Files\SASHome\JMPClinical\15\Clinical\ProcessLibrary with this ProgressionFreeSurvivalPlots.sas file.
  • Replace the existing DiseaseResponseSwimmerPlot.sas file found in C:\Program Files\SASHome\JMPClinical\15\Clinical\ProcessLibrary with this DiseaseResponseSwimmerPlot.sas file.
  • Replace the existing TumorResponse.sas file found in C:\Program Files\SASHome\JMPClinical\15\Clinical\ProcessLibrary with this TumorResponse.sas file.
  • Replace the existing data_strings.sas7bdat data table found in C:\Program Files\SASHome\JMPClinical\15\Clinical with this data_strings.sas7bdat data table.
  • Replace the existing translations.jmp data table found in C:\Program Files\SASHome\JMPClinical\15\LifeSciences with this translations.jmp data table.
Note: After downloading the files, ensure that you replace each file using exactly the same name.
After you replace these files, then re-launch JMP Clinical.
[Previously JMP Note 67297]
Details
Operating System
Windows
Reported Version
8.0
Products JMP Clinical
