JMP Knowledge Base
The preference Hide ODBC Connection Strings changes sporadically
Issue
When certain queries are run in JMP, the preference Hide ODBC Connection Strings is changed automatically. This is most noticeable with slower-performing queries.
Workaround
Attached is a script to help us track when this change occurs. Making this script a startup script will present a non-modal window, indicating the preference is changed. It will also indicate when it is changed if viewing the log during running queries.
This script will allow users to monitor the preference changes and edit the preference manually via File > Preferences > Tables (Windows) or JMP > Settings > Tables (Mac) until it is fixed in a future JMP release.
Details
Operating System
macOS Windows
Reported Version
18.0
Products JMP JMP Pro
