JMP Knowledge Base
The offset slider in the Adverse Events Time to Event report does not add time to the "Days of Exposure" calculation
In the JMP® Clinical 7.1 Adverse Events Time to Event report, if you add time to the offset slider to look for events, the slider does not also add time to the Days of Exposure calculation. The Days of Exposure calculation is used to censor subjects who did not experience an event.
This issue is corrected in the JMP® Clinical 7.1.2 hot fix (link below). The offset slider is then dependent on including the Days of Exposure calculation.
[Previously JMP Note 65973]
Details
Operating System
Windows
Reported Version
7.1
Fixed Version
8.0
Products JMP Clinical
