JMP Knowledge Base
The message "An error (-5001: 0x800700002) has occurred while running the setup" appears during a JMP® installation
This error, which references “(-5001: 0x800700002),” is usually experienced under the following conditions:
  1. You attempt to run the JMP installer from a web browser, cloud-sharing site, or FTP site. You should download the file to your local machine and then perform the installation.
  2. You attempt to run the JMP setup.exe file from within a ZIP file without unzipping the files. You must first unzip the folder structure and then run the file.
  3. Your anti-virus program is blocking the JMP setup.exe file. You can temporarily disable the anti-virus program and then perform the installation.
If you still experience issues during your installation, contact JMP Technical Support.
[Previously JMP Note 67932]
Details
Operating System
Windows
Products JMP JMP Pro JMP Clinical
