JMP Knowledge Base
The legacy Sample Size and Power calculators are retired in JMP® 18
The Sample Size and Power calculators, available in earlier versions of JMP® from the DOE > Design Diagnostics menu selection, are retired in JMP 18. Instead, use the Sample Size Explorers found directly in the DOE menu. These interactive explorers include all of the functionality in the legacy Sample Size and Power calculators, and cover a wider range of calculators for Power, Confidence Intervals, Reliability and Quality.
Comments
aatw
Sorry, I can't seem to find k-sample means (for more than 2 samples). Where can I find it in JMP 18?
Details
Operating System
macOS Windows
Reported Version
18.0
Products JMP JMP Pro
