JMP Knowledge Base
The error "Variable xxTESTCD is not on file WORK.xx" might occur when findings are ADaM data sets and the variable xxTESTCD is not present
In JMP® Clinical 7.1, the AE Narrative might result in the following error when the ADaM data sets are used:
ERROR: Variable xxTESTCD is not on file WORK.xx.
This issue can occur when the ADaM data set has the variable PARAMCD but not the xxTESTCD variable, for example.
This issue is corrected in the JMP® Clinical 7.1.2 Hot Fix.
Click here to access the Hot Fix for this issue.
[Previously JMP Note 65975]
Details
Operating System
Windows
Reported Version
7.1
Fixed Version
8.0
Products JMP Clinical
