JMP Knowledge Base
The error message "No SMQs are available based on the dialog selections" appears on the Standardized MedDRA Queries Incidence Screen
In JMP® Clinical 7.1, the following errors might appear on the SMQ Incidence Screen:
Error:  No SMQs are available based on the dialog selections
Error: Try selecting broad search terms or relaxing filters
These errors appear when the MedDRA files do not include children’s SMQs.
This issue is corrected in the JMP® Clinical 7.1.2 Hot Fix. Errors are removed and no longer prevent the report from running. If the MedDRA files do not include children's SMQs, then the Hierarchical SMQs section is not surfaced.
Click here to access the Hot Fix for this issue.
[Previously JMP Note 65968]
Details
Operating System
Windows
Reported Version
7.1
Fixed Version
8.0
Products JMP Clinical
