JMP Knowledge Base
The Overall Percent Occurrence is not recalculated in the AE Distribution report when you make a selection in the Review Subject Filter
In the JMP® Clinical Adverse Events Distribution report, the Overall Percent Occurrence is not recalculated when you use the Review Subject Filter to subset data. When a filter is applied, the percentages are calculated correctly in the counts table, but the numbers for Overall Percent Occurrence are not updated accordingly in the Report Filter.
This issue is corrected in the JMP® Clinical 7.1.2 hot fix (link below).
[Previously JMP Note 65974]
Details
Operating System
Windows
Reported Version
7.1
Fixed Version
8.0
Products JMP Clinical
