JMP Knowledge Base
The LSMeans Plot may be incorrect in JMP® 14
In JMP® 14.0, the LSMeans Plots in the Fit Model platform might be incorrect for three-way (or higher order) interaction terms.
The values in the LSMeans table are correct.  Therefore, a workaround for this problem is to create the plots manually from that table.
This problem has been fixed in the JMP 14.3 maintenance update.
[Previously JMP Note 64389]
Details
Operating System
macOS Windows
Reported Version
14.0
Fixed Version
14.1
Products JMP JMP Pro
