JMP Knowledge Base
The JMP® Clinical 7.1 API results in a JSL error when closeReviewBuilder() is used
The JMP Clinical 7.1 API results in the following JSL error when the function closereviewbuilder() is used:
The namespace "this" is not defined{10378} in access or evaluation of
'this:updateNavigatorSelection' , this:updateNavigatorSelection/*###*/() /*###*/
Click here to access the Hot Fix for this issue.
[Previously JMP Note 64958]
Details
Operating System
Windows
Reported Version
7.1
Fixed Version
8.0
Products JMP Clinical
