JMP Knowledge Base
The Hy's Law option to include on-trial measurements is not enabled in JMP® Clinical 8.0
In JMP Clinical 8.0, the Hy's Law option Only include on-trial measurements is disabled. This option should be enabled when you select Normalize laboratory values: by Upper Limit of Normal.
Click here to access the Hot Fix for this issue.
[Previously JMP Note 67863]
Details
Operating System
Windows
Reported Version
8.0
Fixed Version
8.1
Products JMP Clinical
