JMP Knowledge Base
The Create Live Report process fails in JMP® Clinical 8.0 when a profile has no data to display
In JMP Clinical 8.0, an error is generated and the Create Live Report process fails when a subject has no profile data to display.
Click here to access the Hot Fix for this issue.
After you apply the Hot Fix, the JMP® Live report publishes, without error, and you see a note indicating that there is no profile data to display.
[Previously JMP Note 67883]
Details
Operating System
Windows
Reported Version
8.0
Fixed Version
8.1
Products JMP Clinical
