JMP Knowledge Base
The Adverse Events Time to Event in JMP® Clinical 7.1 might incorrectly calculate days when datetime variables are used
In JMP Clinical 7.1, the Adverse Events Time to Event might incorrectly calculate days when using datetime variables. The error arises because JMP Clinical is not considering time for the Adverse Event start date in calculating the days.
This issue is resolved in JMP® Clinical 7.1.2 and JMP® Clinical 8.0 with the following logic. If the Adverse Event start date and the Treatment start date both include time, the time is considered in order to calculate days. If one or both dates do not include time, then only the dates are compared. Also, when time is considered in the calculation, +1 is removed from the calculation since time is being compared instead of days.
[Previously JMP Note 66235]
Details
Operating System
Windows
Reported Version
7.1
Products JMP Clinical
