JMP Knowledge Base
Ternary Crosshairs tool gives incorrect coordinates
In JMP® software, if you use the Ternary Plot platform to display your data, the Crosshairs tool can be used to show the coordinates of specific points or areas of the plot. The coordinates shown are incorrect. As a possible circumvention, use the Magnifier tool to narrow in on the plot, then the Crosshairs tool  becomes more accurate.
[Previously JMP Note 64802]
Details
Operating System
macOS Windows
Reported Version
15.0
Fixed Version
15.1
Products JMP JMP Pro
