JMP Knowledge Base
Running Patient Profiles in JMP® Clinical 7.1 produces an error when the EX data set does not contain EXTRT
When the EX data set is missing the EXTRT variable, running Patient Profiles in JMP® Clinical 7.1 produces the following error:
 ERROR: The following columns were not found in the contributing tables: EXTRT.
As a workaround, the user can add a variable named EXTRT with all missing values to the EX data set.
This issue is resolved in the JMP® Clinical 7.1.1 hot fix (link below).
[Previously JMP Note 65522]
Details
Operating System
Windows
Reported Version
7.1
Fixed Version
8.0
Products JMP Clinical
