JMP Knowledge Base
#REF values appear in JMP® data tables when importing from Excel®
When importing .xlsx, or .xls workbooks into JMP®, #REF values may appear within a variable.
This is a known issue that stems from Excel formulas that are nested or conditional. The utility used to import the workbook does not process these formulas, which leads to missing cell references (#REF).
Workarounds:
  1. Save the .xlsx or .xls workbook as a text (.txt) file and import the data into JMP.
  2. Use the JMP Excel add-in to import the data
[Previously JMP Note 64666]
Details
Operating System
Windows
Reported Version
14.0
Fixed Version
16.0
Products JMP JMP Pro
