JMP Knowledge Base
Platform locations in JMP® 14
JMP® 14 includes the addition of new capabilities and therefore, new platforms which have been added to the menus. In addition, some platforms in the Analyze menu have moved, particularly between the Consumer Research and Multivariate menus. The table below shows the location of each of the platforms in JMP 14. The platforms highlighted in blue are found only in JMP Pro.
Platform JMP 14 note
Accelerated Life Test Design DOE --> Special Purpose --> Accelerated Life Test Design
Association Analysis Analyze --> Screening --> Association Analysis JMP Pro; new in JMP 13
Augment Design DOE --> Augment Design
Balanced Incomplete Block Design DOE --> Special Purpose --> Balanced Incomplete Block Design new in JMP 14
Boosted Trees Analyze --> Predictive Modeling --> Boosted Tree JMP Pro
Boostrap Forest Analyze --> Predictive Modeling --> Bootstrap Forest JMP Pro
Categorical Analyze --> Consumer Research --> Categorical
Choice Analyze --> Consumer Research --> Choice some capabilities JMP Pro only
Choice Design DOE --> Consumer Studies --> Choice Design
Cluster Variables Analyze --> Clustering --> Cluaser Variables new in JMP 13
Compare Designs DOE --> Design Diagnostics --> Compare Designs new in JMP 13
Control Chart Analyze --> Quality and Process --> Control Chart
Control Chart Builder Analyze --> Quality and Process --> Control Chart Builder
Covering Arrays DOE --> Special Purpose --> Covering Arrays JMP Pro
Cumulative Damage Analyze --> Reliability and Survival --> Cumulative Damage new in JMP 13
Custom Design DOE --> Custom Design
CUSUM Control Chart Analyze --> Quality and Process --> CUSUM Control Chart new in JMP 14
Definitive Screening Design DOE --> Definitive Screening --> Definitive Screening Design
Degradation Analyze --> Reliability and Survival --> Degradation
Destructive Degradation Analyze --> Reliability and Survival --> Destructuve Degradation
Diagram Analyze --> Quality and Process --> Diagram
Discriminant Analyze --> Multivariate Methods --> Discriminant
Distribution Analyze --> Distribution
Evaluate Design DOE --> Design Diagnostics --> Evaluate Design
Explore Missing Values Analyze --> Screening --> Explore Missing Values
Explore Outliers Analyze --> Screening --> Explore Outliers
Factor Analysis Analyze --> Multivariate Methods --> Factor Analysis
Fit Curve Analyze --> Specialized Modeling --> Fit Curve
Fit Definitive Screening Analyze --> Specialized Modeling --> Specialized DOE Models --> Fit Definitive Screening new in JMP 13
Fit Life by X Analyze --> Reliability and Survival --> Fit Life by X
Fit Model Analyze --> Fit Model Generalized Regression, Mixed Model, and Partial Least Squares JMP Pro only
Fit Parametric Survival Analyze --> Reliability and Survival --> Fit Parametric Survival
Fit Proportional Hazards Analyze --> Reliability and Survival --> Fit Proportional Hazards
Fit Two Level Screening Analyze --> Specialized Modeling --> Specialized DOE Models --> Fit Two-Level Screening
Fit Y by X Analyze --> Fit Y by X some capabilities JMP Pro only
Formula Depot Analyze --> Predictive Modeling --> Formula Depot JMP Pro; new in JMP 13
Full Factorial Design DOE --> Classical --> Full Factorial Design
Functional Data Explorer Analyze --> Specialized Modeling --> Functional Data Explorer JMP Pro; new in JMP 14
Gaussian Process Analyze --> Specialized Modeling --> Gaussian Process some capabilities JMP Pro only
Heirarchical Cluster Analyze --> Clustering --> Heirarchical Cluster
Item Analysis Analyze --> Multivariate Methods --> Item Analysis
K- Means Cluster Analyze --> Clustering --> K Means Cluster
K Nearest Neighbors Analyze --> Predictive Modeling --> K Nearest Neighbors JMP Pro
Latent Class Analysis Analyze --> Clustering --> Latent Class Analysis new in JMP 13
Life Distribution Analyze --> Reliability and Survival --> Life Distribution
Make Validation Column Analyze --> Predictive Modeling --> Make Validation Column JMP Pro
Manage Spec Limits Analyze --> Quality and Process --> Manage Spec Limits new in JMP 14
Matched Pairs Analyze --> Specialized Modeling --> Matched Pairs
Max Diff Analyze --> Consumer Research --> Max Diff new in JMP 13
MaxDiff Design DOE --> Consumer Studies --> MaxDiff Design new in JMP 13
Measurement Systems Analysis Analyze --> Quality and Process --> Measurement Systems Analysis
Mixture Design DOE --> Classical --> Mixture Design
Model Comparison Analyze --> Predictive Modeling --> Model Comparison JMP Pro
Multidimensional Scaling Analyze --> Multivariate Methods --> Multidimensional Scaling new in JMP 13
Multiple Correspondence Analysis Analyze --> Multivariate Methods --> Multiple Correspondence Analysis
Multiple Factor Analysis Analyze --> Consumer Research --> Multiple Factor Analysis new in JMP 14
Multivariate Analyze --> Multivariate Methods --> Multivariate
Naive Bayes Analyze --> Predictive Modeling --> Naive Bayes JMP Pro; new in JMP 13
Neural Analyze --> Predictive Modeling --> Neural some capabilities JMP Pro only
Nonlinear Analyze --> Specialized Modeling --> Nonlinear
Nonlinear Design DOE --> Special Purpose --&g
[Previously JMP Note 62200]
Details
Operating System
macOS Windows
Reported Version
14.0
Products JMP Pro JMP
